My idea for waterproofing batteries
I have a chinese foil drive (eRayfoil / 7larky). The waterproofing of the batteries are not the best. Lost one pack to a dropped cell caused by water ingress so ordering the parts to make some new batteries. As you woud all know good batteries are expensive. Samsung 21700 50S in this case. I want to get the cell life out of the battery, not have it stop from water.
I plan to use 2 part silicon mold 30A. I have had good success with it when I replaced the RX in the foil drive. The 30A mean it is rather solid and the silicon mold means if I want to recover the batteries I still can. At $50 AUD a litter it beats and potting by a long shot. The potting in the factory batteries are really hard to remove. Effort exceeds rewards..
Having pulled apart a few of the water failed parts of this foil drive I have learned it is not the potting but the application that has field. There are voids where there should not be voids allowing water to get to places it should not.
My plan to a 3D printer case. Designed with potting in mind. When I pour to silicon I plan to have a box (to withstand the vacuum pressure) ready I can place the battery in 3d printed case into then surround it with a vacuum bag and then cycle the vacuum on and off to remove the air in the voids. hopefully totally cover the battery and BMS in silicon while keeping it all confined in the 3d printed case. I’ll 3D print some simulated cavities and test first. The vacuum bag is because I don’t have a $500 vacuum chamber that can fit a foil drive battery.
Hopefully this will result in a battery that will last for a long time a salt water environment.
I have a battery guy who does my builds. He recently started potting his efoil batteries with silicon, but to avoid battery thermal issues, he adds aluminum oxide to the silicon mix. No issues with my latest battery. Runs about the same for thermals as my last one that wasn’t potted
