My 4th build so far
fully carbon fibre board with EPS core designed on AkuShaper
1500mm length board provides excellent buoyancy and is designed with a v cut and nose rocker to prevent submarining
Motor is a Flipsky 65161 100kv swinging a custom design 2 blade prop
Battery is a custom bult 13s 18650 40ah Li-ion
Esc is a 75200
Current draw is 14amps at 22kph top speed is 35.8kph
Aluminium mast acts as a heatsink
Wing area is 1400cm2
Total weight is 25kgs including battery
Controller is a custom programmed Flipsky VX3
Let me know what you guys think, I’m open to criticism as I want to create the perfect affordable efoil
Shoutout to Flipsky who have been of great assistance is catering to all my needs and going out of their way to assit and advise me on the perfect setup.
Again congrats on the latest build. Hope the sales work out for you.
Thanks for the answer about the VX3 programming. I thought perhaps you had managed to program and load your own version. I personally would like to alter cruise control to be able to disable it from happening.
Can you help me understand the purpose of this connection?
