My setup doesn’t Work
Hello, I need help!!!
I have a kit:
-6384.
-flycolor not bec 150A.
-Maytech MTSKR1905WF Waterproof
Remote Control User Manual V3.0.
-power supply 36v. 9A
I have managed to pair the transmitter and receiver, but I cannot get the motor to turn.
I have a flycolor programming card which I also can’t program the ESC
When I connected the whole kit I heard some beeps, but now I can’t hear anything and it doesn’t spin either.
can someone help me?
Before you plug in the battery give the remote full throttle and hold it, plug in the battery, wait for a series of beeps to stop and then release the throttle and wait for the beeps to stop and then should work.
It’s also hard to tell how everything is wired, it looks like you have a BEC, do you have a common ground with the BEC and speed controller? Could you put some clear pictures or diagram of how everything is wired.
This is my cable diagram
Are you using a bench top power supply? If you are then I would try using the battery you are gonna use for the setup. I’ve heard of issues trying to use a bench top supply. Not sure if it will help, but worth a shot.
