Mytech eFoil Remote Not Connecting to Motor – Need Help
Hi everyone,
I’m having an issue with my Mytech eFoil and I’m hoping someone here can help.
The remote control shows that it’s successfully connected to the ESC with a strong signal. Everything appears normal on the remote display—battery levels are showing, and connection status looks solid.
However, when I pull the trigger to throttle up, the motor doesn’t respond at all. No vibration, no startup sound—completely unresponsive. I’ve checked all visible wiring and connections, and everything seems secure.
Has anyone else run into this issue or have suggestions on what I should try next? Could it be a firmware mismatch or ESC issue even though it shows connected?
Appreciate any help or insight—thanks in advance!
i took a video as well Video
