I have a very annoying issue on my faux drive assist, (ESC flipsky mini 6.7 PRO, motor 7070 flipsky waterproof, 10S2P parkside LIDL battery, VX3 remote and receiver).
Sometimes, without understanding exactly when, the motor won’t start at all, (without making any noise when using the trigger), ping with receiver is OK on remote, LED are ok on VESC, and the only solution to launch the motor is to help it launch by hand. (tried restarting remotes, VESC, …). After this manual and dangerous launch (always done in air), motor starts to work again normally, and I can stop and start again.
No fault in VESC console when it happens.
Pretty sure the issue is not from the batteries and the receiver, (also used on other efoil setups) Any idea how to debug ?
Looks like maybe the synchro between motor and VESC does’nt work, and this synchro works again when the motor rotates.
Where to look at ? VESC or motor ?
I may have used the motor with a bad connection with the 3 ESC cables once due to bad solder. Tried to switch from FOC to BDLC, because FOC was working at the beginning but then FOC was not working this bad connection, now using BDLC and solders corrected, but the issue still happens from time to time.
Just a thought - when it sticks make a mark on a prop blade and the motor casing so they line up. Next time it sticks see if it gets “stuck” at
the same spot.
Does this happen randomly or only the first time after powering on the ESC?
If the latter, try disable the “safe start” option in the VESC settings. But be careful because if you disable it motor can spin for a split second after connecting with the remote.
It could be a problem with bad contact on one phase. If it is running on two phases only, it does not really work under load though.
What helped with my 63100 in FOC, was to configure a -5 to -10A break current. This is against any logic but it helped with FW 5.1, with 0A, the motor would not start some times.
The problem could be either a short circuit on the motor phases somewhere or a poor connection. i’ve had similar problems like yours due to this, motor would not always start for me.
