New Battery Tech Jetwave
I came across this Jetwave battery that uses 12 semi solid cells. Endurance Battery – JetWave Official
That would make building a battery pretty easy and great specs. I think it might be those cells Farasis S55 Semi-Solid NCM Lithium-ion Pouch Cell 3.7V 55Ah 205Wh High Energy Density Battery
12 cells to solder together instead of hundreds. You just have to sort out the case building and maybe add a BMS. The weight sort of checks out!
My dad was at Boot Düsseldorf and spoke with the guys about this battery. It almost sounds too good to be true.
JetWave had it on display
Yes, had. It was stolen from their stand a few hours later (no, not by my dad).
A day later, a mast from them was stolen as well
I do not really understand why not everybody use pouch cells.Now while it is available as semi solid even more.
