Hi Guys,
now I would like to order my battery for the efoil. So far I have planned 13S with 40Ah for the Flying Rodeo setup. With 14S the cables are used less and I have more power. And it is 2kg more weight…Which values should I have configured? Are my values entered correctly?
For 52V 40Ah lithium polymer battery:
Configured: 14s1p (Need to be customized)
Charge current: 20A (Need to be customized) Discharge current: 90A (Need to be customized) Peak discharge current: 190A (Need to be customized)
Connector: AS150 7mm
Dimension: 340 * 270 * 106mm
Wide: around 11.8kg
Lead time: 15 days
Cost: $ 538 / unit contain 20A lithium charger
Shipping cost: $198 by air to German door to door service contain tax and custom fee taking around 15 days.
I know, they are heavy, but I need the time on the water…
Or does it make no sense to increase the weight by 2kg for further 4V.
13S 40Ah will cost 400,-€
Ellina
Website: www.eleart-battery.com
Phone/Whatsapp/Skype: +86 188 2523 1800
Address: FL 3rd, Building 18th, Minzhi First Industrial Area, Longhua District, Shenzhen, China
We talked a lot, she is very kindly.
She wrote:. It is ok to have Max. continous discharge current: 90A, the Max. Peak discharge current : 190A. We just need to customize the BMS. The LG Battery cells are high discharge rate cells. So it can afford the high current.
Here is the best price we can provide:
For 48V 40AH Lithium battery:
Battery cells: LG imported battery cells
Charge current: 20A
Countinous discharge current: 90A (need to customized)
Peak discharge current: 190A (need to customized)
Dimension: 340270106mm
Weithg: around 10.5kg
Leadtime: 10 days
Cost: $398/ unit contain a 20A lithium charger.
Shipping cost: $251 for two pieces by air to German contain custom fee and tax taking around 12 - 15 days. Total cost is $1047.
The shipping costs are a little bit high, so I think, it is better to take two. May be I sell one of them, ore I use it by myself.
