New Budget Build (Advice needed)
Hey efoilers!
I am new to efoils, but luckily I have worked on many other DIY projects like electric skateboards, onewheels, FPV quads, etc. So I am pretty ok with VESC, battery, motor, and the wiring/ electronics.
I do need help with the rest of the stuff though.
The goal is to make it as cheap as possible but also with as little ‘manufacturing’ work invovled. I dont want to make any enclosures with fiberglass or carbon fiber or molds. 3D printing is OK tho. lol.
So after researching the forum and other places, I came across the inflatable board, like the one elevate.rocks is offering. That seems like a good option. Its cheap and easy to carry.
The issue is designing the box that will fit inside and the mast (is that what its called?)
So questions:
  1. Is an inflatable board a good option? Any cheap links for it? What size is best?
  2. What design/size of the mast/rudder (the stuff underneath) should I go with? I saw a couple optoins on Alibaba:
    Different Models Surf Hydrofoil Full Carbon Surfboard Hydrofoil Wing Foil Surf Sup Foil - Buy Kitesurfing,Windsurfing,Foil Wing Product on Alibaba.com
Which one would you guys recommend?
Flatable is not cheap and the box is many works, but is very nice…
Greetings Frank
It depends, inflatabe is recomnended to save transport space. It is not lighter than a shaped one. Easiest to build is to convert an old windsurfboard.
I am in the same situation. FPV quads, have multple 3D printers, eskate, etc. I am making my own remote at least, not sure anything else needs to be done.
