A prop like the FR prop will give you the highest efficiency. But a super-cavitating prop (like a cleaver prop) will get you the best speed. There’s always a price to pay with speed vs efficiency. Most here will want to strike a balance between the two… So far the FR prop has given decent enough results for a balanced mode.
To test props you need a decent milling machine so that you can cut them from aluminium and a test rig that supplies a constant voltage. Designing the prop is the easy bit…
This is the great thing about building your own efoils and what I love about a DIY forum like this. You develop your own ideas and get to research, design, fabricate and test what works best with your system. This process is what will elevate the product and community as a whole.
