I’m in, makes it three, buy now button ready
So Update guys. I was busy with school (rescuing my grades) and now I have some time to continue. I had some water intake at first ride properly the connection between top and bottom. Nevermind I made all inner electronics waterproof and epoxyied the display and now it’s looking great. I already 3d printed 2 full pieces. I will now update more frequently.
Br your remote builder felix.
Good to hear you have the school under control, still very interested in your efforts with the remote, hope all is well
Thanks i will start building today. I will try to finish 2 in the next 2 Weeks. I have to make a manual and all the documentation. It will be a lot of work.
Beautiful and thoughtful work. I praise you. Finally a waterproof remote control.
I’ll buy a black one or white
Looks good, let me know how to purchase. Thanks
Can you show us what the screen looks like when turned on? What data can you see on it using a VESC?
We need to support our developers​:+1:
now I came from the first ride. gas sensitivity excellent, the volt value is displayed well, water probably doesn’t flow into it. Only the signal is terribly weak - 1 cm of water above the suitcase immediately turns off the signal. I will probably move the receiver forward. Is it not possible to enlarge the antenna?!
Good job Felix, thank you.
IMG_20200727_181808|666x500
Will produce next one as I can see my first still works. I will do it in the next two weeks. Thanks for the sharing. Love to see it.
Hi Felixfoiler! If you plan to have another testpilots, it would be nice, if you can sell one remote for me!
Updated the Design, beacause i tested for 1 week without any flaws.
Update will be shortly available to update OTA. @zaja.cz
Br
Felix
ok i learned a lot over the few weeks of testing. Wifi has some very important safty built in. I had a probelm in the remote, that a cable has become loos and therefor giving full throttle. Fortionalty after 10m the connection was lost and nothing has happend. This will only happen in my own remote, as i used very bad cables for the connection. Not the solder pad broke, the cable did!
Anyways issues i have to fix:
Esp32 is very power hungry with the converter to 5v (0.5a)
When power gets lower connection issues appear.
Reedswitch wont turn off sometimes due to the larg amount of current going through it (Rated 1a)
I already have an fix for all the problems:
The esp32 feather can run from an battery from 4,2-3,2v so no problems should appear with the battery an connection. With the reedswitch i will use a transisor or mosfet to turn it on/off. Also in case the cable should break again. In the code is a detection now built in. in case it would break again it goes to 0% gas.
Br Felix
Sorry for not updaeting but as a 17year old student, getting the driver licencs and working in freetime its always getting difficoult to find time for developing further.
But so far im preatty proud that my remote works so well over the last few weeks. No water inside. Long battery usage. And thanks to everyone which supports my project!
Great work & great humility you are inspiring ! your way of doing things is brilliant ! keep up the good work!
