It’s still a Flycolor but an other model, with more options, more powerful than the 80amp. It’s ready to run when bought but you can set more stuffs on blheli, read about that like I did… The features I like is the possibility to limit the current and you have low tension safety slow down. The 80amp hasn’t got any safety devices.
It’s twice the price of the 80amp but worth the money, it handles better the high amps with twice the power.
You glued one heatsink to the outside , but the other heatsink is still inside.
I wander how much it is a problem…Did you use it as an efoil - long time ?
I glued it with 3M 5200 glue outside of the box. And I made an aluminium plate to replace the amount of plastic I removed to make a good heat transfer between ESC heatsink and outside radiator.
It’s not a problem at all. I can use the foildrive as an efoil without any heat issue until the battery is low tension
Just switched my battery architecture from 8S3P Molicel p42a to 12S2P = 2x 6S2P in serie (to charge with cheap 6S dual charger toolkit M6D).
To sum up my comparison, I’d say that you have more power available until the end of the battery capacity because no sag at all and if you manage your trigger gently, you’ll have more time to play.
Note: Max Speed of my Saite 6384 130kV unloaded = 7000 rpm
I ride very powerful front wings, I started with 1200 mid aspect (1 meter span equivalent 1500) and now I ride 900 high aspect (95cm span equivalent 1200). French brand, Allure Foil. I don’t like big wings, my 900 is the biggest I have now.
Do you use a balance charger for your 10s3p battery? If so, can I ask which model you use? My current balance charger goes up to 8s and I’m keen to try a 10s in the future.
Thanks.
