Newbie seeking prone foiling equipment advice
Hi, I’ve been looking up advice through ChatGPT and get mixed messages on equipment. I live up in NorCal, surfing and a bit of wingfoiling and I am looking to start learning to prone foiling for those mushy days.
I have my starter wing foil gear and wondering if I can use this as my base foil and pick-up the right board.
My wing gear is he older F4 with a 2000cm front wing, 350 rear stabilizer, 640mm fuselage with an 85cm mast. If something looks wrong to use this to start learning to prone foil, I’d appreciate the advice. I am 6’0ft and weight ~190lbs
What size boards did you use when you started to learn? I know the wingfoil board is not appropriate.
Thanks in advance
