Dear Propeller Lovers!
After extensive testing and design changes, I would like to introduce the new generation of Trinity folding propellers for your Assist projects: The TRINITY NXT
Whats better compared to Gen 1:
- Streamlined hub for even less drag
- Reinforced hub structure
- The blades fold up significantly more → Noticeably longer glide
- Slightly smaller pitch for more thrust
- Much better breach behavior when the blades come out of the water → Significantly less thrust loss
- Perfectly balanced system for the smoothest ride ever
The Trinity NXT propeller comes with a motor mounting adapter disk, with which this propeller is compatible with the most common outrunner motors for your Assist Project (check compatibility list).
Trinity is in stock now and can be ordered at Propellerking.com
