Hey Guys,
im starting my second build the next months. I dont have much time to foil atm, but i want to do some things in my workshop currently im still riding my first build.
I will use a GONG WING FOIL LEMON FSP PRO - Wing board - GONG Galaxy (gong-galaxy.com)
I know its very low volume. But im pretty sure it will work with some practice on getting up.
The other componets are pretty standard. I will go with flipsky ESC and Motor. and 7" FR prop
The ESC will be mounted in an aluminum case directly to the Mast for propper cooling.
The only thing im completly undecided is the battery. Im realy thinking about to build a Lifepo pack with 33140 cells. The other option would be 21700 cells. Im planning to get a 14s (2x 7s) pack.
I know some of you already used Lifepo.
I also dont want to use a BMS in my batteries. I will charged them balanced. The reason behind is that i want them to be galvanically isolated completly if they are not in use. There will be a voltage monitor in my board to controll every single cell. Also with an accoustic noise that says your battery is low.
I will start posting here when all the parts arrived and i started my work.
Maybe you lifepo and BMS guys have some advice for me in the meantime I would appreciate that
BR
Chris
