Non (low) power connectors
Are there any good recommendations for reliable connectors for the data lines?
I currently got some 2 pin I use a lot at home, but I feel they get unreliable here.
Likely a bit of corrosion due to salty air?
They do not need to be waterproof.
Somewhat small, easy to work with and reliable would be what I am mostly after.
I like the SP13-type connectors
They are waterproof, but that can only help regarding corrosion, if the salty air can’t get to the contacts
