it seems someone put too much reelx on the plugs and the o rings have swelled very much to the point where the battery connector won’t even latch or even once broke off the tabs of the battery. I tried asking Lift to send some but I haven’t got a response. I need the o rings for the main power connector and the ones for the mast connections. I taking some off a spare ebox but it seems to ruin them taking them off
Do you have a pict + dimensions ?
I think they are standard red silicone o-rings. Just measure the dimensions and you should be able to get them easily
Not sure. I look em to a place that has everything but they didnt recognize it. Lift ended up getting back and some are on the way.
Tried to look them up too ofcourse.
