Options for balancing props
Curious if anyone has any tips for balancing props.
I recently printed a few props. I have coated them in epoxy and then hand sanded them smooth. However I am getting a fair amount of vibration I with them.
Any tips or suggestions for balancing the props?
If they are made for a shaft, put them on a shaft that goes through. Then balance on two blades. I put grub scews in the base to balance.
You can also search for rc prop balancer and find one that fits your props diameter.
I built a balancing tool with two carpet cutter blades:
