This one? Works for me.
you are right, sorry, it didnāt work at home, it runs great at work
thanks for fasr respond
Unfortunately, I am not very familiar with ESCs,
Is it possible to operate this concept with a 150A 6S controller? or is the engine speed too slow then?
I was able to do fly with my 10S skateboard Lipos but I donāt think 6S would have gotten me up with this design. Maybe with a different prop, and it depends on your weight too, I am 180lbs/80kg. Read some more here, you will find lots of discussion about that.
how mush rpm should the motor have, im trying to find a motor that doesnt cost a lot
Thare is build with aquastar 4070 motor that worked, and motor is only 70$.
Look it up on forumā¦
Outrunner which u have to waterproof from the inside or inruner with gearbox. Could be cheapish. Use search option, a lot of users report their rpm, prop, motor, consumption, speed, wings etc
Hi pacificmeister, your work has been an inspiration to me to build my own efoil. I have the motor pod under control, just waiting for my new motor āFlipsky 65161ā to arrive, but now Iām focusing on mountIng the foil to my KRace-70 board (same one you used). I know you put mounting rails in your board but I didnāt see any video of exactly how you did this. Do you have a video or description of this process ? Iāve seen some āadhesiveā mounting systems available but Iām worried these will not be strong enough. What is the best way to do this ?
Hey Wayne, check out video10, https://youtu.be/0XyZq5ZcWeU, it gives a quick overview. I did it really simple. Routed slots in the board and epoxied two longboard fin boxes in place. Electrical pipe for the cables. If you want more structure, route out a larger square and embeds the tracks in high density foam. I have seen foil mount tracks sold somewhere which are already embedded in a high density foam block, ready to be inserted. Good luck with your build.
Hi Iām new here, and you have done an amazing job, Iāve seem all your videos on this build and I would like to 3D prints all this parts to do the same build but I donāt know how. I just bought a 3D printer and I would like to get this cads so I can print them.
How can I download this cads?
Hello guys!
@pacificmeister is it possible to change easily the pitch in your parametric propeller? not sure how to do it
Trying to do a low pitch propeller
Thanks!
