Possible 6384 Stainless Bearing Solution
Found these in my search for suitable bearing replacements in prep for my build. I’m planning on swapping the ceramics out the waterproof flipsky 6384 right away since a lot of you guys have had failures with them and the china SS replacments.
Looks like the MTB industry might have already solved this issue of loads applied to these bearings in their suspension pivots.
I don’t have the motor or my set up built yet but maybe one of you guys needs new bearings and want to ginnie pig these for the greater good.
They have these in both sizes needed 3 total
2x- s6800
1x- s6900
On a side note has anyone had trouble with the potting making it difficult to swap the bearings out?
You want 316 SS as thats marine grade. 440 will corrode in salt water.
10x19x5 stainless steel
This is the bearing you want: https://www.smbbearings.com/firebrick/ckeditor/plugins/upload/Uploads/Documents/bearingpdfs/S316-6800-2PES%20marine-grade-stainless-steel-bearing-10x19x5mm.pdf
Emailed SMB their reply was
“these bearings are for low loads & speeds only & cannot be left immersed in water or they’ll corrode”
when asked if they recommend any
No, sorry – 316 grade is semi-precision at best & only intended for use in simple applications (like food conveyor rollers for example). If you want higher performance you could consider ceramic bearings instead.
The search continues….
I just change them after 500km. As we use the motor with a propeller, best would be to use an angular contact bearing because of the axial load from the prop. The only one I found was not stainless and cost 50€. We are abusing that motor anyways, therefore it needs a bit of tlc any now and then.
Hello
Are you happy of this item , did you have some rust problems?
No rust, but the bearings wear out after some time.
I also tried hybrid ss/ceramic bearings but they did not last long.
Inox is not good too , ceramic seems the best but very more expensive
Based on experience of several people, I suggest to use the stainless steel bearings from the link I posted above. Ceramic wil turn into crumbles in no time. The ones @Jezza suggested look good as well.
Ok , thank you for your advice ; do you need to put some grease on it ?
