As I am currently planning to make my own battery pack, I searched for a BMS that I could use for charging and discharging. I know a lot of you are only using a BMS to charge or even simply using a balance charger to charge.
Anyway, if you know a little bit about BMS or have personal experience with BMS and battery pack, please feel free to leave your 10cents in the comment. I’m open to suggestion about the whole BMS dilemma so let me know what you did with your battery pack!
my Chinese ,a friend order me the bms
i do not have a link to the specific product
this is similar 150A BMS
you just have to ask them and they’ll prepare for you according to what you ask for
Thanks for the link! This looks like a good option and the price is reasonable! I saw on your post that you use a 10A charger. Do you have the link for it? I am also planning on getting a 10A charger for my pack.
Thanks for the link! I really appreciate it. Lastly, I noticed they have different amperage set up. My battery pack will be rated with 210amp max continuous discharge (14p @15a per cell). I doubt I will ever get close to half of that but should I get a higher amp BMS like the 200a or 300a? Or does the 150a also acts as current limiting for the esc and motor?
Alright so I shouldn’t go with the 200a or 300a version correct? I want to order soon and I just want to make sure I’m getting the right one! My ESC is rated 400a (flier 400a 22s). Do I need this current limiting?
i have the same ESC and 150A BMS works great
you do not need more than 150
you should not reach the end of battery discharge capacity
to protect the battery
Make sure this power supply does not have so called hiccup mode when it comes to overload/overcurrent. You need a power supply with constant current limitation in case of overcurrent.
Make sure you find something like this in the specification:
I have very good experience charging with top charge bleed BMS in combination with meanwell powersupply, i have used one for 10 years without fail built into a small electric car, undergoing a lot of mechanical and thermal stress.
For lipo/liion charging you need a CC (and best would be CC and CV) charger/power supply. Yours is CV only. Constant Voltage output it says in the description. So what will happen: battery has e.g. 46V and power supply tries to hold 55V, so huge current will flow, overcurrent will hopefully be tripped and everything will cool down and will trip again after restart of the power supply.
So you either need a CC/CV DC-DC module in between or just get a CC/CV charger.
