Power consumption to high / 70165 120KV motor at fault?
@GodoyGDI
I don’t see how your post relates to this thread other than you use the same motor.
The thread resolution was changing the prop and removing the duct - not a defective Flipsky VESC.
There are lots of successful builds here that use relatively current Flipsky VESC products so not sure how accurate your opinion is on that.
