We are preparing to introduce a new motor and propulsion design. Unlike traditional propeller-driven systems, it delivers thrust with a quieter operation, reduced power input, and improved efficiency. The result is greater thrust with extended endurance on the water. This technology is also suitable for DIY users, and we invite you to stay tuned for the release.
Thanks for listening to the feedback you received on your earlier posts.
However it would have been better imo if you had waited until you could post actual details about your product rather than the “watch this space - coming soon”.
Dude, I’m ready to start following your news! I’ll let you know when I’m completely ready.
Hi from hsfoil in Australia- were dying for a water jet propulsion system to marry up to our twin motor etow units.
presently using twin flioski 65121 combined with flying rodeo props and (soon) bremote remote differential steering…
can you PM me a hello so i can stay in touch -
info@hsfoil.com
Mark
Can I make a post about this power unit in the Build section?
Why not post it here and continue this thread?
You started this thread to generate interest in what you are “manufacturing” and it would appear several people are interested. You aren’t going to generate more interest by stating another topic somewhere else on the forum.
Think about it… the “build section” would be for someone who buys your product to “build” their personal solution.
Is it a commercial product and you are representing the manufacturer or is the post supposed to advertise it → manufacturer category
Did you build something yourself in a non-commercial sense → Build category
In your case it is clearly the Manufacturer category
Well @Asufun , interesting stuff !
May we have some specs like diameter, thrust, weight.
Would be good for a tow boogie in a safety manner. Certainly on efoil too. All depending on specs you’ll give us ![]()
thans for reply agian
thans for reply first
Yes, this is a shaftless thruster — quieter, with a higher power output ratio (which means longer endurance), and safer.
No you not, shaftless ROV thrusters aren’t new. What you meant to say was you are introducing a new product to your line-up…
Again no…
A shaftless thruster is way less efficient than a std propellor and in order to get the same thrust requires more power.
Is anyone making DIY ROV’s on this forum? Last I checked it was a forum for Efoils and foil assists which this simply won’t work for.
Don’t just try sell any product you can here, try sell relevant products…
Thank you for your careful and thorough reply. The data I shared is basically from actual tests. When I have time later, I’ll share the test video.
I see little has changed as your post doesn’t seem to make much sense.
If you had the time to reply - why would it take longer to present your video? Why keep us in suspense?
Secondly your spec sheet states a maximum speed far slower than anyone would foil at so why would an engineer such as yourself feel that this device is usable for our purposes?
Thank you for your continued interest. The high-power version is still under adaptation. At present, this level of thrust and power is mainly used as auxiliary propulsion for SUPs and lure fishing boats.
So why would you post about a product that is NOT relevant as @jezza says?
“Don’t just try sell any product you can here, try sell relevant products…”
Please stop the nonsense!![]()
Great product. I want to start using it immediately. Unfortunately, I don’t understand what devices it can be used on and, more importantly, why I need it at all. Maybe I should take up fishing? Or take up SUP competitions? I think I could win the slowest time award.
The speed parameter I casually took a screenshot of is just the test speed for SUP board adaptation. This motor has a wide range of applications, and the debugging work for various scenarios is already nearing completion. Testing should be finished within two months. Thank you for your attention.
For future updates, you can subscribe to my website about this product: https://hydrofoildrive.com/product/powerful-brushless-underwater-thrusters-12v-24v-48v-electric-thruster-motors-kayak-rov-thruster-kits-for-boats-and-diy-applications/
or follow us on social media at Redirecting....
