I’ve created my own problem and looking to see if there’s a quick fix until I can get back to help a friend.
I switched out a motor for a friend of mine’s diy foil assist. He was using the foildrive 2 blade on his old motor but as I replaced his motor with a flipsky, it was a good time to try the flipsky 2 blade prop.
He didn’t like the flipsky prop so I printed the adapter for the foildrive prop and fitted that.
He went out to try it and and has realised the foildrive prop is other handed to the flipsky one.
Trouble is, I’m not in the area at the moment and he either needs to switch 2 of the phases on the motor to reverse it or get other handed blades for the foildrive hub.
Thinking I could get a file for foildrive blades and mirror them and get my son to print them?
The other option is to re wire and re-waterproof the phases.
