Hi
I recently purchased a Maytech MTSKR1905WF V2.0 remote. I connected it to my Hobbyking ESC with no success. Pairing between remote and the receiver was OK and the received power up OK. After checking the output PWM signal it was 100Hz and 3.2V: see image oscilloscope below
In the manual its specified that the PWM signal should be: “Throttle signal output: 1-2ms 50Hz PWM 5V Max”
Any one else who has problems?
