Progcard32 shows warning sign. What to do?
Hi all,
During a session my motor phase cables came loose underwater. After the session I repaired the cables using solder seal connectors. However, now the motor runs erratically — it shocks and stutters instead of running smoothly.
When I connect the Progcard32 I get a “WARNING: TH Loss Protection” message.
I also noticed that the startup beep of the ESC is very faint compared to normal — without the remote switched on the motor barely makes any sound.
All wiring checks out fine — continuity on all three phase wires, no short circuits between wires, and the remote connects normally showing standard display.
I have tried:
  • Resetting ESC to factory settings
  • Changing motor timing, startup power and rotation direction
  • Replacing the solder connections
Nothing helped. Could the ESC or receiver be damaged by the incident? Any suggestions welcome!
Rolf
Update: I forgot to mention — the ESC is a Maytech MTSF160A-WP32. The motor is a Flipsky 6384 140KV waterproof. Remote is Maytech MTSKR1905WF.
