Hi All,
Im looking for a prop guard for a Flipsky 65161 motor to use with the fliteboard prop if anyone has one that would be great.
Many Thanks
Hi All,
Many Thanks
This might work
I don’t find the use of a guard adds to safety. It also adds drag to the setup but up to each to decide.
Thanks I will give it a go
Bit buried in my build thread, but this worked pretty well for me. I think it adds significantly to safety.
link for prop guard STL:
https://www.dropbox.com/scl/fi/n30ohncwnvg1jq1wsn798/prop-guard-v3.stl?rlkey=0lpjdu1n9dtx5q8gvjov6m37g&st=j0tl0t72&dl=0
this one’s probably better- support fellow builders!
Hi, Thanks for the prop guard link, looks pretty cool so I will print it later. What screws did you use to mount it? And what print settings would you recommend? Thanks
That looks very nice. I am skeptical about it improving efficiency as nobody has ever seen that on a normal propeller like the flite prop.
DO you find it noisy?
