I am about to start prop testing. I will run the 100kv waterproof Alien motor at 12s. I plan to print a lot of props for testing. All ducted for safety. The prop with the most thrust will be CNC machined.
Can you recommend some starting points for pitch and diameter?
the only test i did was: jump in the water with it
I don’t have any number, but lying on the board, quite forward to avoid taking off (so with the back of the board dragging in the water) at full throttle, it’s FAAAAAAST
and if you apply the throttle when the nose is underwater, the submarine mode is scary…
see video here: 80100 direct cooling - #22 by Mat - Builds - FOIL.zone
