I am currently trying to figure out, which cells I should use for my battery pack.
After reading through the forum I saw many successful builds with Samsung 30Q Cells.
The problem for me is, that these cells are really expensive (500€+ for 12s 12p pack)
Due to this I did some research and found a company near to my hometown, who would sell me used ebike cells for a very good price (0,4€ per cell).
The cells are Sanyo 18650 2200mah with a max discharge of 10A.
I already bought 30 cells for testing, and I think they are in a very good condition. Nearly all of them have 2150-2220 mah of capacity and an internal resistance of <50 mOhm.
Now my Question is, if it is realistic to use these cells for an efoil?
My plan is to use a 63100 motor and a Vesc 6.
As we can see at @V_S build, it is possible to run this setup with 120A motor current.
If I am now building a 12s 15p battery pack, each cell of my pack would have to draw 8A.
Do you think this could be a cheap alternative to all the really expensive battery packs?
30Q and VTC6 are around 12mOhm. Lowest internal resistance is the Sony VTC5A with 9-10mOhm.
I personaly would not go for batteries with internal resistance higher than 20mOhm. My 14s11p VTC6 batteries can get 45°C after an average discharge of around 1C (33A)
I have used a similar cell source, used ebike batteries. All tested and matched up to form an equal pack.
Mine are <35mOhm, the 12s12p pack does get warm (50degree?) during discharge but all acceptable.
My cells to compare the specs: LG LGDBMG11865 Cell Specifications | Second Life Storage & Solar
