It helps to play with “model” parts when you start.
Here are very quick 3D STLs of the Reisenauer chief, flange, 10mm shaft, bearing, lip seal… for you to play finding out about volumes, dimensions, shaft length adjustments, etc…
Cheers
Cheers
Good enough for your little kids or for project schools to play with
Every single piece here is 3D-printed (except the last m10 metal bolt) along with @MaB prop
Quite similar to the real world
