Quick tow boogie Rom1
I create this thread to stop asking question on other thread.
So I create a tow boogie I inspired my self a lot of the tori tow of Hadou and most of the same part:
-esc sequre 12200
-motor flipsky 6384
-regular maytech remote
It works a couple of time fine after some fine tuning in particular on the position of the tow bar I was quite happy with it has I manage to go out with a surffoil of 38l and a 1000HA foil which was my goal.
Unfortunatelly after a couple of session I start having some issues.
It seems my motor when in the water don’t manage to increase speed, stop and resume and so on.
Sometimes on a different session it just rework and then it stops again.
Not reliable at all.
I manage to reproduce the issue in a kid pool I have in my terrasse.
I attach 2 videos:
1 out of the water: https://photos.app.goo.gl/hpAez87JvJN7H86v9
1 in the water where we see the issue: https://photos.app.goo.gl/Ze3qUfeU2gLccsTt8
I suspect some issue on the 3 wires that link the ESC to the motor, in particular I don’t like at all the connector I chose and I am wondering if I crimp correctly the cable in it.
Any advice welcome
Which connectors did you use?
Crimping without soldering ?
https://fr.aliexpress.com/item/1005008070268003.html?spm=a2g0o.order_list.order_list_main.27.21705e5bAhguWE&gatewayAdapt=glo2fra
I use this no soldering just crimping and after investigation it seems I didn’t protect the connection properly so I have corrosion on them. Will change them try to protect better and see if it helps.
Hi Rom123, nice build ! I like the idea of using a metal plate. How did you put the metal plate and the bodyboard together ? Did you glue them together ? If yes what glue did you use ?
Some sika but it is not really needed as the metal is stuck to the bodyboard by the screws that fix the tow pole and the mast.
