Ray Foil DIY kit shipping WORLDWIDE
Video linkhttps://www.youtube.com/watch?v=ftHjo20_0ZM
Ray Foil DIY Kit – Build Your Own Compact & Lightweight eFoil! :man_surfing::zap:
We’re excited to announce that the Ray Foil DIY Kit is now available and shipping around the world! This is the easiest way to build your own lightweight and compact eFoil, designed to fit any wingfoil board.
:small_blue_diamond: Ultra-Lightweight – Just 18kg total weight, much lighter than most eFoils.
:small_blue_diamond: Customizable Battery Setup – Install batteries directly inside the mast.
:small_blue_diamond: Max Capacity – 12S5P LG M58T cells, up to 1.2kWh for 60-90 min ride time.
:small_blue_diamond: Modular & Flexible – Choose only the parts you need for your build.
:dart: We are preparing for the next batch of parts!
:bulb: Available Components:
:white_check_mark: Custom-made mast (choose your length)
:white_check_mark: Mast CNC plate 165x90mm
:white_check_mark: CNC bottom adapter for your fuselage (we have in stock gong V2, Sabfoil kraken and moses, we can make other brands also)
:white_check_mark: Waterproof connectors & button
:white_check_mark: BMS, ESC, remote control, charger, motor, propeller and more
:envelope_with_arrow: Want to start building? Email us with the parts you need at hello@rayfoil.surf
:ocean: Or check out our full eFoil at www.rayfoil.com
Post some photos please
It’s easy to post all theese things without posting any price tags.
We have a few used masts availible (with flipsky 65161 motors) for 2000€. (without other electronics).
Also new parts (CNC mast plate, mast, bottom cnc adapters for Gong V2, V2, Sabfoil kraken, Sabfoil moses, and RRD)
Also Gong V2 wingsets from 200€ (used) or 300€ (new). Used boards from 400€, new boards from 600€.
Shipping from Estonia.
Is the 2000€ price including batteries? I’m also interested in purchasing just the mast. Would you be willing to sell it without the Flipsky 65161 motor?
Hello Pavel. The used mast have 65161 motor installed, also waterproof latching button and charging connector. No other electronics. You need to install your own VESC, BMS, battery.
We also can sell brand new masts, mast plates, adapters.
Write us hello@rayfoil.surf
Can you share some photos and mast dimensions so we can evaluate the the feasibility of packing diy battery and other things inside the mast, that would be bery helpful. thx!
Mast fits 5x21700 elements in one row. 12S5P mast is little bit more than 84cm long. Mast lenght can be customised. The shortest mast we have done for one surf club is 60cm mast with 8S5P battery - It is super easy for beginners.
Write me a DM and I can send a drawings from the mast if needed.
