RAY FOIL Review ![๐Ÿ”‹] Battery inside the mast!
RAY FOIL Review ![:battery:] Battery inside the mast!
https://youtu.be/uyWyeuTTNOE
Probably many of you DIY experts thought or even made this idea but this is a first time i see it is done in a commercial product. What is your opinion, pros and cons of battery inside the mast setup?
This is not a foil assist. this is a full power efoil! 18kg total which is great! 1h riding time.
Cheers!
Clever: the small box above the mast with the rear charging plug (for full battery inside the mast), antenna. I donโ€™t think there is enough room for the ESC in this box
TOP VIEW:
From the site: how do you get a solid mount for the mast and an ESC in such a small volume ?
BOTTOM VIEW:
A Flipsky 65161, 120KV fitted with a FR Foldy prop like Fliteboard. Well done David !
Iโ€™m not amazed by the 18kg of the complete board fitted with the RayFoil. A bare LIFT efoil board is already 10-13kg because of its reinforcement.
The brand could go below 18kg choosing a rigid board (non inflatable). The STX 5.5 120l Inflatable board is 7kg. So the mast + motor + battery + plane is 11 kg.
Has any one heard or seen pictures of the similar Takuma project with the battery inside the mast ?
Takuma project was just an idea and 3D render which may or may not come in reality. But here Andres already made a commercial product that works.
There is no need for any reinforcements here because there is no battery compartment inside. It can be attached to normal light foil boards, so I think 18kg is impressive.
That was my point.
The question is โ€œis 11kg impressive for a Flipsky 120KV motor + mast + plane + battery + ESC + receiverโ€ ? I donโ€™t know. More over, we dont know yet what is the battery flat setup like: 8s5p, 10s 5p ? How many cells can we accomodate in a mast.
Would you have a picture ?
I think itโ€™s 12S5P, but I canโ€™t remember where I saw thatโ€ฆ
