Recommended battery connector for high amp and waterproof
Hi guys! I’m planning to build a board with a 14s7p battery and looking for a waterproof battery connector that could handle 160A continous. What would you recommend? Thank you!
What can you be building that would use 160A continuous? :flushed:
Amphenol Surelock, either the 5.7mm 120A or the 8mm 200A (bulcky). For an eFoil battery connector, the 120A shoul be sufficiant. They are not cheap but good quality. They are NOT antispark.
I use regular 8mm bullet plugs with little waterproof cases. They fit perfectly.
Could you be helpful and provide the model/size or a product link for these cases?
Inline connection “cable to cable” or cable to box?
Was it an out-of-the-box solution? Or was modification needed?
Thank you, Pavel, for sharing!
