At Reisenauer’s, they seem to only have the right 8mm pinion for the Superchief 4:1 and not the 5:1…
Leaving me no choice but purchasing a 4:1
For those of you who have the SSS 500KV, is that a big problem to choose the 4:1 with the @Silvio’s metal prop over a 5:1 ? I have no intention to go over 10S…
I have Reisenauer 1: 5 and the same propeller on 390kv engine with a 14S battery
from my experience it will work not bad but I think you will have high current consumptionou you can reduce the motor shaft
Our version of the SSS 500KV has an 8mm shaft, and the pinion sold by Reisenauer is also 8 mm so in this specific case no need to lathe the motor shaft.
