Hi guys
Had problems with vesc restrictions
The vesc cutoff when my battery bluetooth bms show exactly 50amp.
This is for 2 new vesc 200
So
Just purchased 2 flipsky vesc 200
I Upgraded both with water cooling block.
One run an inrunner and the second one outruner.
I run motor configuration on both and all fine.
But every time the battery reach 50amp the vesc cutoff.when i release and pull on the throttle again its again run until 50amp and cutoff again.
Is there any safety restrictions on the new vesc 200?
I increase the motor configuration
Max motor to 150a and max battery to 180a and still it cutoff at 50a.
Any idea where is the additional restriction :)?
Could be several things like bms protection (i guess not?) overcurrent protection due to loss of control, power setting too low, erpm scale down setting, duty cycle scale down setting etc
I think you need to upload some log screens and the settings screens to get any good input.
Thank
Yes not the bms as it’s working fine on the flier 400.
But yep
Seems like i don’t have a choice but to study how to operate the logger:).
This logger is not straight forward:).
I was able to get it recording before savings the files but was not able to run them
What did you use to watch the videos please:)?
