I bought an Axis aluminum mast thinking it was hollow inside and I could just route the motor cables inside the mast.
However, turns out that the mast has some material inside.
Does anyone have experience with routing cables inside the Axis mast?
Would be interested to hear some pro tips on how it can be done.
Update: I got it done, but removing those glued in plastic parts from the inside of the mast was super hard and it took me a whole evening. Using a heat gun to soften the adhesive didn’t seem to help. Couldn’t tap them out. I ended up using a very long drill to drill many holes in the plastic and then tap out the broken up bits.
If I remember correctly maybe about 30mm thick.
For my other mast I got a metal bar that had roughly the size of the hollow mast area.
I heated up the area to weaken the adhesive and then used a hammer with the metal bar and that worked well.
For the heat, I imagine you used a heat gun? If so, did you find heating up the sides of the mast helped? Or did you apply the heat directly down the center channel?
