Running a 6384 motor in FOC mode on VESC
Is anyone here successfully using a 6384 in FOC mode?
I have the issue that the motor does not get going once in the water, everything seems to be fine when testing on land without load.
Here are the general steps I did to set it up with my VESC:
1.) Motor Wizard: Medium outrunner, 14 motor poles. Detection goes through fine and outputs the following values:
Screen Shot 2023-03-11 at 1.25.02 PM
2.) Then I changed the max motor current to 90A and adjusted max battery current, cut off values etc according to my battery pack
3.) Wrote motor settings to VESC
The motor spins up fine during dry testing without load, but does not in the water. If I change settings from FOC to BLDC then it also works fine in the water.
Any ideas what’s wrong? Is anyone here successfully using their 6384 with FOC?
How’d you get on? I’ve got mine set as FOC but have not tested yet. Maytech 100a vesc, 12s battery and 6384 motor.
Hey, what do you mean with “How’d you get on”?
Currently I’m running my 6384 in BLDC mode until I find a solution for FOC.
Hello, yesterday I did my first test with a 6384 motor and a FLIPSKY VESC 75100 and 10S battery.
With VELOCE XL wing very slow, and with CURVE X I didn’t have enough speed to get up.
FOC metod
Weight 93kg
Quite strange that it works for you dry and not in the water. Where do you have the VX3 receiver located?
FOC not recommended for more than 6s. BLDC is fine
i´ll try, thaks @NickOldfield
Why? FOC is a control algoritm, not limited to a certain voltage.
Following up on this, has anyone had success with FOC on an 6384? If yes, could you share your FOC parameters for comparison?
I’ve got it working nicely when thrust is low, but with more throttle trying to get up on foil, the motor will cut out.
Chatgpt sent me to this thread.
With FOC my 6384 ran seemingly way underpowered at only 700w. Then after troubleshooting it stopped spinning altogether in the water.
Switched to BLDC and it worked again and up to 900w. But seemed considerably underpowered as I was hoping to get at least 2000w.
Super strange, I have never seen anything like this with RC plane motors.
Anyone have any ideas?
Something wrong with the motor.
Do you have a spare identical model?
Had a similar issue and in VESC motor detection the faulty one had much higher internal resistance.
FOC is pretty sensitive to that, so it fails.
BLCD still works.
You could check VESC tool for your current values and then run detection after. If they change significantly, that should point to the problem.
Thanks. I troubleshooted all morning with ai help and got it working.
Could you please share config changes?
I spent 6 hours troubleshooting and making changes I wouldn’t even know where to begin
