@JuanP I use this front wing, it’s tested. Kite Hydrofoil Front Wing - Fully 3D printed by dinceraydin - Thingiverse
Heyyyy, any updates?
I make Magnet button for Antispark Switch on FSESC 6.6 (VESC), IP68 Waterproof safety switch
Your mast looks very nice! What did you use to paint it?
I use gelcoat. I applied a gelcoat layer to the matrix, then laid fiberglass impregnated with resin. The same operation as in this photo
assembly of a hydrofoil with a motor. the process of installing the motor and wings on the mast
The weight of the masy is 2,040 kg
inserts for fuselage mount
painted mast
mast with maytech motor 65162 and hudrofoil wings
eFoil builded successfully, now I’m riding
Great!And now improve your skating technique!We also have everything ready for the test, I hope to post a video on the weekend!
I made a new carbon fiber mast for eFoil with cable canal, it’s height is 880mm and weight is 1.96kg. It is significantly stronger than same fiberglass mast. Only now I can say that I can ride normally. With new mast I can fly over the water for a long time and with pleasure. On the previous mast, my flight lasted no more than 10m.
nice work. The boys from Russia have good ideas.
very nice video
this motor looks exactly like HGLTECH 65162 motors?https://www.gd-hgl.com/products/65162-100kv-120kv-motor?_pos=3&_sid=6cfd6a86b&_ss=r
@HGL-Tech we all know your motor now , I gave it a like on another thread but please do not SPAM every thread. It makes your company look like a JOKE!
