Russian prop on Ebay for the 65162
There is something wrong : 220USD for 43kg max thrust 120kv 14s.
@funboards.at which Maytech motor did you use when you got 72kg of bollard (static) pull with a 10€ polished 3.5HP plastic solas prop on yout MTI65162 at 4200rpm - 54 V / 146 A:
