I kept the original bearings for the first 20 runs or so then switched to sealed bearings (which are not sealed). I just change them out every 20 runs or so. None have failed yet, just get louder with time.
I have not added a thrust bearing.
Nice setup! What lipos are you using? I’m trying to source some but am not having success with hobby king.
I am using a brand from china found on ebay. They are 6s 10000mah taotuo batteries. They have held up very well so far.
Ok I want to buy a 80100 motor to join everybody else! Haha. The problems I’ve had with the gearbox setup has been ridiculous. @s9tim is this the motor you have?
I saw a few with the same 80100 model number.
Yes that is the same motor. The other one you see probably is a sensored motor which we do not need for our use.
Even though it is back ordered it usually ships in a week or two once you place the order.
Hi there are the coils coated with epoxy?
Thanks.
No coating on the coils. I only epoxied between the magnets.
The prop looks like it will cut you in half if you fall wrong. Does anybody have plans for covering it? Would be nice to hear about efficiencies lost with a duct on such a big prop.
Also, has anybody had success putting the 100kv APS 6384 PowerGlide motor with a duct on a foil board? I would love to know battery life because I am hoping to get up toward an hour of run time.
@s9tim awesome job!
I would like to ask you if you cut the motor shaft by yourself or you order the motor whit a custom shaft as you required?
I cut it myself with a dremel tool and cutoff wheel.
I made a hands free flush adapter for my APS 80100. I can hook it to the hose and it flushes the motor with fresh water while I tend to the batteries, etc. I will add the file tomorrow.
now that’s a cool idea.
do you spray the motor with wd40 or some form of oil to keep the bearings from rusting
I soak it in a bath of corrosion x about every 6 runs or so.
Usually ducts help to increase the efficiency. Helps to prevent tip vortexes. But if the ducts cross sectional area is too big you might get a lot of drag.
Amazing
What a topic.
Years ago I made all kind of electric outboard, jet surfboard, but also a direct drive surfboard.
It was a c80100 turnigy winded to 75KV, but always out of sync problems, the motor makes noise and vibrates, timing problems with the ESC. without a prop no problem. I tried all kind of controllers, also big 18 fet Ebike controllers.
So I ordered a Revolt 10 or 12 motor, ordered it with epoxied stator, expensive ceramic bearings, also same out of syns problems. Also with less pitch props. I gave up.
Now I still do have 1000 euro Lehner 7040 300kv motor water cooled from the Lampuga project and have a Neugart ple 80 1:8 so I can run about 1800 rpm prop speed for what I always believed was a good prop speed for outboards.
Since all efoil builders are around 4500 rpm. I could buy a Neugart ple 80 1:3. But now I see that you have great succes with a direct drive under water without loosing sync with the ESC that is really wonderful ! Maybe also much more silent. Since the torqeedo outboards make a lot of whining noise.
Also I want to build something that can reach about 40km/h and with your motor direct under water I think you can get so much power out of it.
About 3d printing I don’t know anything, I see many people here doing this, I tried a few free 3d drawing programs, I don’t have the skills I am afraid. Would you like to share your files ?
Hi Louis , did you let go your project with twin 52mm mhz drive ?
40km/h would be hard to acheive but not impossible
Low rpm will mine big propeller …
With your motor you don’t want to try the mhz 64mm with vesc 75/300 for a jet board ?
Update: efoil build now right ?
Hi Alexandre, I had a 64mm MHZ Jet.
The thing is, I don’t want to TRY anything anymore
I want to build something now that already has proven itself. Our friend s9tim and others already made it so simple. I hope I can ride this ride with others this time.
Can you share the specs on that mhz 64mm jet.
What motor are you using and how much power?
Mhz 64mm jet, specs are at their website. Lehner motor liquid cooled 7040 winding 6 278 kv under load 11kw input i was running in the video. Forget that. Hydrofoil way more fun, speed, less sound, less power, less money, easier to build. Less batteries needed. And you fly and that is really cool
“I want to thank Matt and the others on here who have shared their files and did most of the design work.”
Where can i find these files? Somewhere online?
that thread has all my parts scattered through ![]()
the beginning is a test version, final version for new liquid force mast is later in the thread.
