Saite 6374 vs 6384
Help me decide between Saite 6374 and Saite 6384 motor. With a 12S3P battery and an FD prop.
This build is meant for a wide range of users—different weights, from beginners to advanced riders, and various board or foil setups.
It needs to cover pretty much everything in the foil-assist category.
Do you think the 6374 is sufficient, or should I go ahead and order the 6384?
Also, what’s your real-world experience with Saite motors in general?
In general, the bigger will be better. But it depends on your battery. What is your max amp for the battery? How many cells in parallel?
3P 45d cells.
It is not obvious, that is why I am asking for experience with these motors.
We have tested the new fd hp motor and it was NOT stronger than their regular 6374.
