Just about to start sanding and glassing my 3D printed PLA duct. Any advice on the technique, number of coats etc,
Hello perso I sanded with 120 and 600 with water before putting a plastic primer ( 2 thin coats). Then three coats of MOTIP black paint (spray paint) and to finish 2 coats of SPRAY MAX 2K matt varnish.
This is the method I used for my Electric mountain board and it is shock and scratch resistant…
https://www.e-sk8.fr/t/foraker-trampa-holypro-35-12s12ah-overion-6374-escape-6-4-metr-pro/3014
Cool thanks, I might give it a try it sounds a lot easier and less messy than using epoxy
Thanks for the pics, what brand of plastic primer spray did you use?
MOTIP PRIMER PLASTIC
https://www.pecamax.fr/primer-special-pare-choc-et-plastique-400-ml.html
I bought it at FEU VERT car store
Hi guys
Thanks for all the suggestions.
Finally getting round to this! As I still have a little epoxy left I might just paint the duct with epoxy
How does it react to PLA and how do you stop it reacting in the pot while you are painting it on?
