30 min flying and new Seaking ESC burned, cooling OK. Why?? My weight 105kg? :-))
sss motor as Pacifikmeister
What Seaking ESC was that ?
Quite often, the mains reasons are:
1- water in the inrunner motor,
2- one motor phase cable got detached see Mark’s comment and his burnt Seaking too,
3- ESC not SW limited in temperature,
4- exceeded ESC nominal and/or peak current,
3- to be continued…
I just had the same problem. Sure makes a big mess. I did not get beyond 50 feet. No water in the pod. I will take the pod apart to check the connections.
