I am a naval architecture and marine engineer that graduated from Istanbul Technical Univesity. My graduation project was self-balanced hydrofoil. I manufactured it and tested in circulation tank last year. IT WORKS EFFECTIVELY
Note: Aft hydrodoil’s strut was short. So aft of model didn’t leave from water
Maybe I’m wrong but this is what happens with every foil wing if it’s mounted the way you did?
In my opinion, this is just a video about how a hydrofoil works.
‘‘One problem that a hydrofoil craft can experience is the height of the waves being greater than the struts. Also, if the craft is traveling faster than the waves, the foils could break to the surface and outside of the water, resulting in a loss of lift and a negative angle of attack when the foil dives into the next wave, making the craft crash into the sea.’’
I prevented crashing into the sea when foil dives into next wave. The struts are symetric foils.They dont have lifting force.
