Selling Mast Motor ESC Combination
Hello everyone,
I am selling my exchange/second mast.
Installed is a 65161/65162 motor, with an Easyfoil VESC and a Metr/Voyage GPS module. On a RL mast with Mastplate. The ESC is waterproof molded and fitted with an XT90 connector.
Compatible with the VX3.
500€ without radio without propeller
600€ with Easyfoil/VX3 remote control
700€ with Easyfoil/VX3 remote control and 7 inch propeller
Regards
hey, what’s the acceptable voltage range for this ESC?
mast size and compatible foils can be attached?
Does remote signal pass well without external antenna?
BWESC V4 Platine: 140 x 45 x 16mm
Eingangsspannung: bis 67 Volt (16S)
Thats the information from easyfoil
Mast length is 75cm and fits to rl wing system
Remote signal working great, there is a external antenna in the esc hosuing
Mastplate screw pattern is 165x90mm
Hey… Do you still have the articles?
If yes, I have a few questions:
-I have a takuma with broken mast/motor and would like to put the VESC inside the board. Does it need cooling? Can the VESC be separated from the mast?
  • what is the distance of the holes on the mast plate?
Thanks,
Eric
Hi Eric
yes, still have it
the hole pattern is 90x165mm
you cant separated the vesc from the mast.
I think the vesc is cooled pasive via the aluminium
regards
