I am running the maytech remote. I bought it when it was on sale and then waterproofed it properly. It’s good enough for what I want, but I wouldn’t pay full price for it! I’m not sure when a new remote will be out, it might take some time.
So I think I am all set to finally see if everything actually works.
I will have a go this evening using one battery and the ARC200 GUI, setting the temp cutoff to about 65 degrees so that it would cut out way before the ESC burnt as you suggested
Is there an “out of the box” standard setting with the ARC200 that you could then just go in and customize certain sections or will it always need the full custom set up as in the videos above?
Anyone see anything majorly wrong? I assume the main battery wires are the black and red and the blue is the other one. I have nothing connected to the throttle connector on the arc
I just connected mine up last night. I used the pwm on the pin6 of the throttle port. Found this pic since the arc200 wiki changed sites and is missing a bunch of pictures.
Also remember to test your and set your failsafe (shut off remote or lose singal). Mine was set to a low value that the arc200 interrupted as full reverse. Got rid of reverse on mine now and it correct shuts off the power I shut off the remote.
