Seven Larky efoil components for sale - Australia
Make an offer for any components or for the lot. Happy to post within Australia - not sure about posting batteries to other countries.
2 waterproof batteries with waterproof connectors - Nominal voltage 44.4v Max voltage 50.4v
size 353mm by 79mm by 44mm 2.5kg 444wh
Cells Samsung 5OS (BMS)
The 2 batteries have done a total of only 26 sessions (all on Strava if you want to see them. Videos of some sessions are on Instagram (search Murray Ceff)
3 remotes - one wrist style, 2 handhelds (one working)
2 motors - MP6384/80KV Max Power 4000W instant
Rated power 2000W Max Input voltage 48v
Max thrust 43 kg Sensor 316
Weight 1.5kg
One motor is brand new, never used. Other one has done 26 sessions only
equipment box (battery housing)
Various length cables inc one on the mast (mast not included)
Equipment Box (battery housing) - yes, I do have the nose cone. It has an external antenna. I broke the antenna wire and it is not repairable - not by me anyway. Maybe you can fix it, or maybe you can use some of these components to put together your own Efoil/Assist? (Everything was working fine until I broke the antenna)
MAKE AN OFFER FOR ANY COMPONENTS
Price for the lot $2000.00AUD or near offer.
Happy to send detailed pictures of anything you want
