Hi all,
I’m an engineer and foiler. For my own builds I got tired of jumping between CAD, spreadsheets and XFoil, so I’m building one tool for it: SHAPELine. The focus right now is board design.
What it does today
- Board, foil and eFoil design with a live 3D view (iso, top, bottom, side, front, exploded)
- Board from three photos (top, bottom, side) or a quick mode with sliders
- Outline, rocker, deck and cross-section editor with B-spline control points, curvature comb, “Smooth curves”, “Fair surface” and a tolerance setting
- Buoyancy and volume distribution: displacement over length, waterline view, and a check of how much volume your setup needs for the total mass
- Material and light preview: wood, carbon, agave, matt to gloss
- Parametric front wing, stabilizer, mast and fuselage (area, aspect ratio, profile, angle of attack)
- Templates, versions, quick save, export
In progress
- Scan to surface: turning a scanned board into a clean, editable surface (surface reconstruction). The raw scan is a noisy mesh with holes and dents. I fit a surface to it and check it with zebra analysis and curvature plots.
- Guided scan app for phone and iPhone, so you can digitise your own board in a repeatable way. Your board is not my board, so this needs scans from the users themselves.
- Foil simulation: pressure distribution, wingtip vortices, lift and drag. Internal panel method, with optional XFoil export/import for real polars.
Access: it’s a closed beta. You register and accept the terms of use, so I can keep control of who uses it and protect the software while it’s still rough. About 50 people are testing already, and their feedback goes straight into development.
Thanks for your help
Willy
