I recopy you answer from the other thread here to clarity:
"jkoljo
10h
I think I’d prefer to discuss build details in my actual build thread, but here goes…
I am using Metr Pro CAN + separately bought MRo M9N GPS for logging. Unfortunately Metr is currently discontinued, and the original creators are working on a new project. Meanwhile I would look into the used market or the new Vesc Express logger. It seems to be a capable unit, but I also think that the software is not as finished as Metr.
I am using the 30A BMS, not 60A. I am not using my VESC through the BMS so discharge ratings don’t matter. Only the charge rating matters, and it is 20A for the 30A (discharge) model of LLT BMS.
You should not connect packs with different parallel cell counts in series. Unless the actual battery capacities are an exact match, you’ll end up discharging the lesser battery more, which may not trigger a low voltage cutoff early enough. This may cause the lesser battery to discharge too deeply, which damages the cells and makes charging dangerous as well.
Also, water-cooling for the VESC is probably not necessary. And it’s definitely not necessary for the battery. For me it’s enough to have the VESC in an aluminum box. It doesn’t even conduct the heat anywhere, but still stays cool enough."
HERE MY ANSWER to YOUR COMMENTS on Battery calculator for eFoil - #28 by macfly1202
1/ about Metr : I am trying to find one and have a look to Vesc Express logger
2/ super clear about BMS: you use it to charge and balance only not during riding - make senses why 30A only
3/ About my idea of 2 pack I know it must be the same in serial. I was saying I need to find which battery is more suitable from 6S10P to 6S14P but it will the same (6s10p+6s10p, 6s12p+6s12p or 6s14p+6s14p) ! safety first !
4/ about watercooling: I prefer to be more safe first and, for sure, a pump a another point of potential failure. Only data will speak > so I need to see the raw amp at high frequency to see what happen.
In my step 2 build, when I will made the board, probably I will use a passive system with CNC alu box.
Because I know very well Ardupilot, I will probably use it as a logger if a can’t find a Vespress logger or Metr. I have all spare for Ardupilot on shelve.
Kind regards, Jean
