Does the solar panel can generate enough power to maintain the full electricity for a house?
In my case, 1 panel gives around 300W constant during sunny day. Size is 100x50 cm and its a bit older panel. U could generate 1.2kW on 2sq meter board. Not sure how much panel efficiency went up last few years. There is a guy who been making solar catamaran i think, search him on forum he should have more good info.
Hello, the best solution for this is flexible solar pannel. So you are in the midle of the river, open your 15 square metter flexible solar pannel, charge it during the time you take a rest and then continue up-flying the river. This is what I’m already planning.
